Results 1 to 3 of 3
Thread: How To Blow Up An Engine.....
  1. #1
    Super Moderator LegalAlien's Avatar
    Join Date
    Mar 2009
    Location
    Tranquille Valley
    Posts
    2,985
    Default How To Blow Up An Engine.....
    ...With Gasket Goo.
    Lots of mechanics use Goo to save a few bucks on gaskets, so what's the problem?
    This clutch gasket (picture 1) had some extra liquid Gasket Goo applied to it...probably after a mid season clutch change. The pen points to the excess Goo oozing out.
    As the screen fills up with crud (picture 2), the motor has to work harder to pump the oil, which is bad for power! Eventually the motor will starve for oil and spin a rod bearing.....
    New Gasket = $10.00............New Motor = $3,000.00
    Careful with that Gasket Goo!
    "Teach me to do it myself" Dr. Maria Montessori (1870-1952)
    BC Riders Member # 20
  2. #2
    Senior Member Dudette's Avatar
    Join Date
    Aug 2009
    Location
    Clearwater
    Posts
    1,402
    Default
    Oupss......
  3. #3
    Senior Member
    Join Date
    Mar 2011
    Location
    Prince George, BC
    Posts
    173
    Default
    back in my distant past when I was always working on my old bikes and cars, I often had things apart and re-used old gaskets,,, I used to use the spray on gasket glue , often sold for carb gaskets,, you can put a few laayers on that old gasket, and not have the squishy goo factor you get with silicone or permatex , out of a tube... if you have to use the tube types, wipe it on spareingly. NO BLOBS.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
