Results 1 to 3 of 3
Thread: Stuck Bolt Will Not Budge HELP
  1. #1
    Junior Member Achievements:
    3 months registeredTagger Second Class500 Experience Points
    Awards:
    Master Tagger
    verdo's Avatar
    Join Date
    Jan 2017
    Location
    Vancouver
    Posts
    15
    Question Stuck Bolt Will Not Budge HELP
    I recently purchased a Memphis Shades Batwing Fairing Click image for larger version.
ID:	2552 that I was very excited to install on my bike. Everything seemed to be going fine until I came across one hex bolt that seems to have been put in place by that hands of Thor. It will not budge. I have tried WD40 to no avail, then went and got something a bit more powerful Super Creep which is meant to help with corrosion and loosen off the bolt and still no help. We tried using an impact drill to break the bolt free and instead broke the bit and the bolt remained snug as a bug. I’m not really sure what else to do to try and get this bolt out so I can install the fairing. The bolt is close to striping if I try to much else and I don’t want to drill it as I need to install a new bolt for the fairing mounts to fit on. I might try taking a chisel and hitting into the side of the bolt and seeing if that make breaks it free but I really don't know... Any ideas? Maybe a suggestion where to take it?
  2. #2
    3 months registered500 Experience Points
    FrogDog's Avatar
    Join Date
    Jan 2017
    Location
    Maple Ridge
    Posts
    26
    Default
    This sounds like a Galling effect more than a macho man or corrosion effect. SS 'stainless steel' especially is more prone to that than other mediums if that is what it is..
    The only option I see is to break and/or cut the fastener then replace without to much damage to the unit itself
    FrogDogz Ridez -
    YouTube
  3. #3
    Awards:
    Master Tagger
    verdo's Avatar
    Join Date
    Jan 2017
    Location
    Vancouver
    Posts
    15
    Default
    Well after quite some time a fussing and worrying about this stupid bolt I took it in to Daytona Motorsports and the guys in the back were able to get it out in no more then 10 min. Glad to have gotten it out and was able to install the fairing. The bolt itself had no corrosion on it once removed, was clean. Just a pain. Oh well trouble behind and the open road in front! Click image for larger version.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
